I recently bought an ETS 150/3, after sanding a flat surface I noticed my sander appeared to be running out of balance. The orbital sanding motion seems fine, its the random rotation of the pad that seems out of balance.
From my understanding of a random orbital sander, all the sanding action should be in the same plane as the object you are sanding, say "x-y plane". However, my sander is vibrating or moving in the "Z-plane" vertical to the surface I am sanding as the pad rotates.
In the picture below, there is movement of around 2-3mm in the "G direction", as the pad rotates in the "R direction". I have tried several pads and the problem remains. It appears to me one of the bearings is out of alignment.
Is this a normal movement of the sander, and does anybody else experiance this situation?
Thanks!
Sam
Thanks!
Sam
