ETS 150/5 What are recommended grit ranges
The ETS 150 is capable of using grits between 40 and 4000. Recommendations would depend on what you'll be sanding and how you'll be finishing the wood.
You can use the search tool on our website for some guidance.
https://www.festoolusa.com/abrasives
If you want to give more details, maybe we can steer you in the right direction.
Shane
Well Shane, looks like I didn't look hard enough myself.  [embarassed]  Thanks.
It depends on what you do for projects.
Personally, I run that one more in the lower end. I find it is a nice grab at 80 grit to clean up a deck, but also competent up to 180-220 range.
Edit: Oops, just noticed this is an "Ask Festool" and not a general question  [scared]
