ETS 150 Query
ossietim
Hi  can anyone help with this ....?
I am trying to find the part no. for the BEARING BOLT ETS 150/3?
I found the no for the ETS 150/5(492027)
Is it the same part on both the 3 & 5? Or is there another no.?
Thanks ossietim
Tim,
On the US electronic parts catalog, the bearing is listed as 401601, Bearing  DIN 625, for both the ETS 150 /3 and /5. So, it appears to be identical in both machines. I would think our friends at Festool Australia would be able to help you identify the part if you contact them.
Shane
Update: I asked our service manager about this and he noted:
"Yes, they are the same in the ETS 150/3 and 150/5, but you need a special bearing puller to remove the output bearing (26)."
[attachimg=#1]
Thanks Shane that was a quick reply [cool]
I found the part no.797812 and thought it might be differant but as you noted it is the same
I did as you suggested and  ordered the part from my dealer with the part no. you provided.(it was good to be able to get an answer 1 hour later and at 11pm australian time)
Thanks again Shane
