Extension Vacuum Hoses for CT22?
edesilva
Maybe I'm thick-headed, but I'm having a rather confusing time with the Festool hose options for the CT22.  What I want is an extension -- probably larger diameter than the original hose -- that I can use to run the hose up a wall so its out of the way.  I don't really want the whole boom set up.  Seems like all the hoses in the catalogs come with the rubber thingus that you stick on the tools...  I just need a male-to-female extension cord.  Do I have to buy another cord then a separate adapter?
Actually, what I *really* want is someone to tell me there is an option that doesn't involve a $100 vacuum hose.  As much as I seem to be getting used to parting with my green with the Festoolization of my shop, I would not be adverse to having someone tell me "oh, you just need an adapter from here, an adapter from there, and a run of pool hose from Home Depot."  (I might live with the loss of anti-static technology if there was a cheaper route).
Any insight from anyone into either problem?
Well, i know Tinker for one has successfully used rubber plumbing fittings (the kind with hose clamps, you'd use them for a cast iron to ABS or similar connection) to get various hoses and adaptors working together. For power you'd just need one dedicated plug-it cord that you could use between the tool and another extension cord back to the vac. The plug-it vac hose works pretty good, to the point that I rarely use a plug-it cord alone. I'm pissed if I forget it at home.
That's right, I forgot about that Seth. That's one of the best examples in this category.  ;D
Eli
lest you forget naina?
there are the rotating adapters in both static and anti static for all three hose sizes that have the 50mm end on them. Not the rubber thingy end. Pt #452891 thru 452896 that you could use to at least make the festool connection if you choose to stray with other stuff. pt #493047  connector will connect two 50mm/2'' hose ends together and pt #452897 hose reducer is tapered to connect 50mm to 36mm or you could be creative?
Bill do you mean the plug it vac hose is NAINA? I did not know that. You poor bastards. :-\
    Thats right Eli. Apparently cord through hose is a no, no. :'(  Been tempted  to make my own.
I wonder if you could get the vac hose and ends as a replacement from overseas and put in your own plug-it?
are you doing that volunteering thing for us? a couple thousand should do. the dollars down, would you mind fronting them. we'll tell you how they work.
That's how my Uncle the customs broker got a case of Nokia videophones. We caught them in Madagascar on the way to Nigeria and turned the shipment around.
Born at night, not last night.  8)
Now if you want to front some money, I'm good for the hoses. You'll have to wait for them to get here from Germany before I ship them though :-\
Thanks for all the replies.  I swear I've tried a normal shopvac hose and it didn't fit...  In fact, I'm 99% sure I've got one of those Ridgid pro hoses in my shop now, connecting my cyclone to my router table.  I'll pull it off this evening and give it a try.
I'm also curious about the conduit.  Maybe I'll just take my festool hose to the borg and start plugging it into things every aisle.
  For the 2" conduit to fit into the CT you need to shave down the OD a little. I used a rasp.  Same for where the shop vac hose connector fits onto the conduit at the other end. But then the shop vac hose connector makes it easy and secure to attach whatever vac hose you are using. I switch between the D27 and D36 quite often. I have not been able to find any conduit or plumbing fittings that are a  perfect match.  I wanted as few connection points and suction robbing joints as possible. Thats why I didn't use reduction fittings or the like. I also went with the conduit for the smooth curves, no tight turns.
    I ran an extension cord from the CT to where the hose attaches. That way the plug-it  cord and hose come from the same location.
    I have been using this for quite a while now, and it works very well. For my shop arrangement I do not need the arm to swing. For sanding the cord and hose get hung, about half way along there length, from the ceiling. Giving totally  unhindered movement. For everything else it just hangs from the pipe end.
Setting up dust collection equipment has been a frustrating and time consuming experience for me, too.  I have a CT 22 E, a Fein Turbo II and an old Craftsman 16 gal. vacuum machines, and hoses for each plus a growing collection of adapter fittings (most of which are failed attempts to find a match in coupling to various other machine fittings).  I also have Festool's Boom Arm which comes with a 5-6 ft length of 50 mm AS hose both ends of which have 2 1/2 inch (nominal size) retatable male fittings, and a 11.5 ft length of 36 mm AS hose which came as a component of a Festool cleaning kit.  I keep my collection of fittings and the dusting hand tools in the Systainer 4 in which that cleaning kit came, and drape the extra hoses over a Rubber Maid garden hose hanger mounted on the wall of my garage/shop when not in use.
Here are some options for your consideration.
Buy a "Mr. Nozzle" hose (about US$40 through many on line and catalogue vendors) or one from Sears Craftsman or others with or without attachments and a short, standard grounded extension cord.  The fitting on your Festool CT 22 E will accept any standard 2 1/2 inch (nominal size) shop vacuum hose.  You may find it better to purchase an entire shop vacuum system from Sears, HD or Lowe's and plan on using the cheap vacuum machine for nasty and wet stuff.  I have used my Festool C22 with hoses from Festool, Sears Craftsman and Fein and vice versa.  The Mr. Nozzle hose, the Fein hose and most of the Festool hoses come with a 2 1/2 inch (nominal size) male fitting that is a direct fit to the Festool vacuum machine (and most any other USA shop vacuum).  But the other end of the Festool hose, as you know, is of reduced size to fit Festool machines their dust collection hand tools.  The Festool dusting tools fit the tool end of the Fein hose and the Fein dusting tools fit the Festool hose, too.  In fact, I prefer to use the Fein tools most of the time.  My Craftsman hoses are about 5 - 6 feet long and both ends are equipped with a 2 1/2 inch (nominal size) male fitting; the Craftsman dust collection tools all have a 2 1/2 inch nominal female fitting.  So any Craftsman tool can be connected to any end of any Craftsman hose.  And Craftsman has a double female fitting to connect two of their hoses together.  Note that the exact dimensions of the Craftsman and Festool 50 mm hose-to-hose (double female coupling) are slightly different and due to subtle differences in the size and taper of the male (2 1/2") fittings sometimes I use the Festool connector and sometimes the Craftsman connector.
Bear in mind that the Craftsman hoses are flimsy relative to those from Festool, but priced accordingly.  That said, my Craftsman hoses are still functional after 30 years of use/abuse.
For the electrical supply you can use any standard 3-wire (grounded) extension cord.  I don't usually see them offered less than 25 ft in length.  I bought a 50 ft 12/3 outside rated extension cord, one male and one female end fitting.  Cut the cord into two shorter lengths.  Make one correspond to the length you need for your shop setup and use the other wherever needed.  Or you can buy 12/3 rubber covered wire of the length you need, end fittings and make up exactly what you need.  You might also want to consider buying one of those "3-outlet" extensions that HD, Lowe's and others sell in lengths as short as about 15 ft.  Check FOG for posts by Dan Clark on the utility of this type of extension with the Boom Arm, especially if you have any Festools that are not equipped with Plug-It cords.  Festools not equipped with Plug-It include the earlier model RO 150 (no longer being sold in USA), and current models of RS 2 (half sheet sander) and DX 93 (triangular orbital sander).  The multiple female outlet receptacles will allow you to keep a Plug-It extension in one outlet and to plug in a Festool not equipped with Plug-It at the same time so that triggering either one with activate your CT 22 E.
If you go with Mr. Nozzle or Craftsman, and the off-the-shelf power extension cord, your total cost should be less than $100, and give you added flexibility.  Of course, if you choose not to use Festool's AS hoses, you may find static buildup becomes a nuisance problem under low humidity extended run circumstances.  I have not experience much of a problem with the non AS hose supplied with my Fein vacuum.  I have experienced static shock many times in the past when using my Craftsman vacuum to sweep the floor of my garage/shop, especially during the winter when the humidity is low.  Although the Festool AS hoses are expensive, they work as advertised.  I am thinking of purchasing at least one additional Festool AS hose for use with my Oneida Dust Deputy, and making up short lengths of 36 mm and 27 mm Festool hose to couple to my Boom Arm setup.  The Festool 50 mm hose through an adapter available from Oneida connects nicely to the outlet of the Dust Deputy, and Festool's 36 mm hose without any fitting is a snug slip fit onto the inlet of the Dust Deputy.  Several Festool products have oval DC ports (1010 router and DX 93 among them) and can only be connected to the elastomeric fitting supplied with the 27 mm hose.  But using my TS 55 to rip or when routing with my 1400 router, a 36 mm hose works much better because it is much less prone to clogging.
Beware the black plastic connector fittings sold by many vendors, including those participating in the Woodworking Show that travels around USA.  Most of these fittings are made of rigid plastic (?ABS?) and fall short of what is needed because they have zero or very little taper on the surfaces that are supposed to friction fit with another component.  What is needed is for a manufacturer to step up and begin making fittings with tapered connection surfaces, preferably from a material that is somewhat elastic.  Rubberized ABS or vinyl or TPE (urethane, e.g. Santoprene) would be a big improvement over most of what is now being marketed, and would enable a lot more connections to be successful.  (The adapter I purchased from Oneida is somewhat elastic. but stiffer than the tool end fitting on Festool's 27 mm hose.
Now, if someone can help me with connecting a Hitachi CH 10 CMS to my Festool vacuum ...
Dave R.
"a growing collection of adapter fittings (most of which are failed attempts to find a match in coupling to various other machine fittings)"
Amen.  Between 4" schedule 40 pipe, 4" flex hose, shopvac hose, festool hose, and 1.25" pool hose, my shop is looking more like a plumbing supply house than a woodshop.
Yes, a growing collection.  If and when I am ever done, I'll have a great set of extras to donate to Habitat For Humanity's "Restore."
Has anyone tried heating and resizing plastic fittings for their dust collection system needs?  I have not tried it yet, but it should be possible.  Many, if not most of the many available dust collector and pipe fittings are made of thermoplastics.  A heat gun or hair dryer may work to soften the plastic. To expand an undersized fitting, I am thinking that maybe I could turn a tapered mandrel on my lathe, and tap it into the fitting that needs to be expanded.  To reduce the OD of an oversized fitting, I am thinking of trying a ring compressor (used to install a piston fitted with rings into the cylinder of an engine).
Dave R.
If you have a lathe, why not use it to shave down a larger connector. Would be much cleaner than trying to stretch a smaller one.
Eli,
I have done that, usually using abrasives or a file.  But many times there is not enough wall thickness, especially on the black plastic fittings that are commonly marketed for woodworkers through various stores and catalogues.  If the manufacturers of these products would simply put 2 to 2 degrees of taper on the intended mating surfaces, that would be a big improvement,
Dave R.
      WOOD Magazine issue 181 dec/jan 07/08 page 10.  Blow torch and hose clamp to reduce pvc pipe. I imagine a heat gun would work just as well and safer. Put hose clamp on pipe. Place fitting into it. Heat pipe. screw the clamp tight to squeeze it smaller.  Don't see why the same wouldn't work to enlarge. By heating and starting the resize with a funnel or some other cone shape. Once the end of the pipe is large enough to start the fitting into it then the fitting could be used to push it the rest of the way.  I wish I had this shop tip when I was putting my stuff together.
Dave Ronyak said:
Eli,
Dave R.
Aha! But you were going to turn down the fittings out of HD ABS drain fittings because they're much thicker, weren't you, you clever little monkey.
Well, through the purchase of a craftsman pro hose (which, by the way, comes with no less than 7 different fittings that, for a good period, stymied both the salesman and I in terms of how they attach to the hose) and some bodging things up, it all seems to work fine.  Extension hose is now connected to CT22 and original hose.  I can also connect it to my router table, with my router DC connected to my cyclone.  The surprising thing I learned was that I can connect my Festool hose up nicely to my Delta miter saw.  The rubber thing actually fits nice and tight inside that fitting.
My collection of strange fittings has continued to grow however.  Why I don't just throw them away puzzles me...  Packrat instincts--"it will be good for something someday".  *sigh*
