Exterior Wood Choice for Post Covering
I'll add my Boral comments.
We have a home on the SC coast and have Hardie Plank, Axek and Boral exteroir materials.
For flat surfaces the Boral look better, and paint appears to hold very well.
I've wrapped deck posts in redwood and while it didn't rot it was a pain to maintain primed to prevent sap leach and they used one steel nail that left a rust mark.
Brice Burrell said:
Ipe works great as decking, I'm not a fan of it for trim.  Checking and warping can be an issue.  The bigger issue is the ipe doesn't hold a finish.  You're fighting an uphill battle with any semi-transparent finish on wood outdoors.  With ipe that hill is more like an insurmountable mountain.  Expect to reapply a finish every year, or maybe every other year if you want to maintain the look.
I've replaced far too much exterior wood siding and trim to ever own a house like the OP.  Brick and synthetic for me.
Yes, Ipe does not hold a finish. All of the Ipe I've installed has come with the caveat that states " use Australian timber oil or nothing". Aus TO lasts for two maybe three years...maybe. I like the natural look, but on the flat it is not for bare feet or socks. If you go natural on the flat, shoes are a must.  I would guess that AUS TO works better than anything on the vertical, but you are looking at a 3-5 year recoat effort.
Good luck.
Yeah who puts anything on ipe? Not taking anything is the trait that makes it last 75 years outside. If you want it  to stay a certain color dont use ipe. If you want to solid stain color the wood no way can you use ipe. If you want it to weather naturally then it a great wood to use.
If the trim split of crack it may have not been the select top grade. In my experience if I take a piece of decking and use it as a piece of trim, its going to last longer, crack or cup less, not more than a horizontal piece. I have at least one ipe 3 season room in Chicago and the trim, exposed beams, deck, railing and posts, everything just looks as good as it did 20 years ago, only the color is different.
I have gone through this will my suppliers and a couple of times was certain the trim type ipe stock (1x4, 1x6" etc)  I ordered was a knock off becasue it was not the same as the decking in the same shipment. Possibly it was just not the best of the best of the ipe, not sure.
I found another supplier and sure enough he was changing near 1.5 times more than I paid. I still have one piece of that ipe from the bad supplier and it does have checks in it, I have had no issues since I switched suppliers.
So shop carefully when buying expensive lumber(specifically exotics, you never know what you are getting), hand pick it if you can.
I hate boral, I hate synthetics, been through it and have used several types over the years and nothing is non maintenance forever. My mom's synthetic deck and railings look like crap, she is on her 3rd deck now in 25 years using 3 different type of non wood products. She wanted to get away from Cedar as she tried to stain hers at the old home and ruined it and it was never easy keeping it looking how she thought it should look. A huge mistake, just let it go grey mom is all I told her, she wouldn't listen. So on the new home she went non wood and still had issues of one type or another.  Had she gone an exotic wood it would still be going strong. I guess I am just a wood guy if I have to maintain it I will.
The OP's house is stained, natural ipe wouldn't match the color once weathered.
I had a piece of ipe with several different finishes on it in my lard, southern exposure.  In a year they all looked pretty bad, the next year all of the finishes were gone.
Naildrivingman said:
Yes, Ipe does not hold a finish. All of the Ipe I've installed has come with the caveat that states " use Australian timber oil or nothing". ...
The 2-part epifanes says for teak, etc.
Does that also work on ipe?
I don't know what it is about Ipe that finishes don't like. I've not finished teak before, but I live in a boat community and very few boats are adorned with finished teak. I'm guessing that teak and Ipe share some common characteristics. Just a guess though.
After looking at your home I'd favor redwood for the veneer, as that appears to be what your siding is.
From my experience, redwood has a lifespan that is 2x the life of cedar. I built a deck with redwood over 25 years ago and just replaced it with cedar last year, because the price of redwood was 3x the price of cedar. We'll see how long this cedar one lasts. My guess is 10 years or less.
That's the reason I prefer stone...it will last for 200+ years.
