A child's log building kit mostly made from old fence boards
Frank, what an outstanding project.  I hate to say this in lieu of the Karma Gods but; I can't wait to have grand-kids.  Once again, if the karma gods are listening, allow me to stipulate my time frame.  Having a 15, going on 16 year old son, I would like to wait at least 10 years please.  By waiting, this will allow me to prepare many projects.
Frank that cabin is awestome.  I bet Isla and Ethan are as happy as.....grand-kids in their own home.
Very nice, you should be very proud of them,
Tim
Frank,
   You are amazing. And what a great gandfather you are. I have just one question:
Log_building_kit_from_old_fence
When are you going to assemble these boards into a house boat cabin...now that would be hot (and top heavy.)
PS - I couldnt copy your boat pic
Thanks for posting that Frank!
I am going to have to make a small set for my son so he can play with it in the Living room.
I really, really like Ethan's T-shirt in the crane picture. What is a little boy from Ontario doing wearing a Vancouver Canucks T-shirt  ;)
Dan Clermont
Dan Clermont
Because wearing a Red Wing's shirt would not be tolerated so close to Toronto!!! ;D ;D
greg mann said:
Dan Clermont
He'll be wearing a Pittsburgh Penguins shirt very soon.
Frank Pellow said:
nickao said:
This project, Charles desk and Eiji's Doors are my top three, with Eiji a little ahead. Bill Wyko is in there somewhere with his amazing vases and boxes too..
Anyone want to convince me otherwise?
Nickao
Nick, that's elite company you are placing this project in.  Thanks!
And, good luck to all of us.
No problem Frank.
I think a lot of brownie points for re-using lumber are in order. The project is something anyone here with kids is probably interested in also. That means a lot to me. And as  usual you show the Festools in action!
Nickao
Paul, I never thought of Velcro.  Now that you have mentioned it,  I think that we can make good use of Velcro tape on some of the new pieces that we are thinking of adding to the kit.  Thanks!
Timmy, thanks and I hope your dreams of becoming a granddad come to fruition.
John, do you mean a house boat that really floats?  That?s a tall order but one that I will think about.
Dan, I hope that you do make a set and, if you do, please let us know about it.  And, by the way, I like the Canucks.
Greg, that's a good one and, perhaps, true.  When I was younger, I did play pickup hockey many times in the Toronto area wearing a Montreal Canadian sweater and got away with it -but Detroit is probably worse.
Brice, never the Penguins!  Go Red Wings Go!  (in spite of what I said to Greg above)
Nick, I do manage to re-use a lot of wood in many of m y projects.  My neighbours are now all trained to ask me before they put  any wood out for the garbage.
18 June 2008:
Ethan and I got together last week to finish the crane.  The crane last appeared in this thread under the March 29th heading and, at that time, Ethan and I were last testing part of it.  The crane requirements are:
- It must be possible to operate it from inside a building and it must be able to pick up objects outside the building
- It must be possible to reach out from withing the building a obtain objects that have been raised up with the plane
- It must be possible to rotate the crane on the horizontal plane
- It must be possible to move the crane back and forth on the horizontal plane
The rotation was handled via this small inexpensive piece of 'turntable' hardware from Lee Valley:
[attachthumb=#1]
This was installed on the bottom interior edge of a window frame.  On top of it, we screwed a section of 4x4 cedar with a hole drilled in the middle:
[attachthumb=#2]
The pole slides back and forth within the hole and the 4x4 provides sufficient stability. The rest ot the window frame has been left empty in order to satisfy the need to be able to reach out of the building and grab objects that have been winched up with the crane.  Here is the whole thing in operation:
[attachthumb=#3]
13 July 2008:
The big project for me this week has been completing a lot of parts for the log construction set.  Included in the mix were new types of parts, some modifications to old part types, and a lot of duplicates of some of the old part types.
Last year we simply placed square acrylic sheets on the roof and did not secure them.  This bothered both me and the children.  The solution we agreed to was to frame each of the sheets making panels and to secure each of the framed panels to the roof with removable dowels. I prepared narrow (1 cm by 6 cm strips) of cedar of the appropriate lengths.  Of course, the source of the cedar again was old wood that I had previously "rescued" and stockpiled.  In this picture:
[attachthumb=#1]
the 1 cm edges of 20 strips are being gang-sanded with a Festool Rotex 150.  The strips are wedged between a stopped strip and the end vise on my woodworking bench.
Then I sanded both 6 cm sides of each strip with the Rotex and the ends with a Festool linear sander:
[attachthumb=#2]
Observant folks will notice that there is no hose attached to the sanders in the above pictures.  Unfortunately, my Festool CT22 vacuum is at Pellow's Camp.  :( Fortunately I could work with the door open.  :) There is a very good chance that my next Festool purchase will be a CT Mini.
I did not attempt to gang-sand the sides or the ends.  Each panel required eight strips and I made enough for five panels.  I have four acrylic sheets and cut a square of 6mm thick plywood for the fifth panel.  Later on I will make at least three more panels using plywood.
The strips are applied with screws and glue along all four edges of both sides of the acrylic (or plywood) squares and they are overlapped at the corners.  Here is photo of one partly completed panel:
[attachthumb=#3]
As you can see, the strips were painted red before they we used.
I have tried to avoid making special parts but it appeared that a special rafter was need along each edge of the roof.  They, too, were painted red in order to make them easy to identify:
[attachthumb=#4]
Observe the four holes in the top of the rafter.  Small sections of dowel (yet again red) can be loosely fitted into these rafters:
[attachthumb=#5]
Then the panels (each of which has two holes slightly larger than the diameter of the dowels on one edge) can be positioned over the dowels:
[attachthumb=#6]
I hasten to add that the roof is not intended to be leak proof.
Isla, in particular, did not like the fact that the kit had a door frame but no door.  This week, I finally got around to making a door.  As with all the other parts, it had to be light enough for a child to lift and to place into position.  I have attempted to have no parts that an active and intelligent child of age 6 cannot manage.  All the cedar wood for the door is 12 mm thick.  The construction was very simple as can be seen in this picture:
[attachthumb=#7]
The door hinges were somewhat more complicated.  I remembered from my summers working on a farm as a teenager that there was some type of hinge that allowed us to simply lift some of the barn doors off their frames, but could not remember any details. Research led me to an ancient type of hinge called a 'rat tail hinge'  Such hinges are still available today but they are usually hand forged and quite expensive.  Further research led me to rat tail hinges machine made in Italy and sold by Lee Valley for A much less expensive $8 a pair.  Here is picture of me experimenting with one of the hinges:
[attachthumb=#8]
The trick is to mount the hinges so that you can:
  (1) align the lower flag (the part on the door) over the lower rat tail (the part on the frame) first,
  (2) lower the door a little bit,
  (3) align the upper flag over the upper tat tail,
  (4) lower the door the rest of the way.
Here are pictures of the door beside the frame then mounted on the frame:
[attachthumb=#9]
[attachthumb=#10]
Ethan requested some way of building a platform into his structures when he builds things such as forts, ships, and rockets out of the construction kit.  I came up with the idea of placing three adjacent notches on the logs on opposite walls and then bridging those notches with three regular half logs used as crosspieces:
[attachthumb=#11]
A simple platform part can then be snuggly fitted over the crosspieces:
[attachthumb=#12]
I tested the platform by standing on it and attempting to tip it off the crosspieces.  I could not do so.
In the photo below, the platform is being used in conjunction with the crane:
[attachthumb=#13]
I'm sure that we will thing of additional uses of the three adjacent notches and plan to cut them into many of the older parts.  We welcome suggestions about such parts or any other new parts!
Here are three different views of a structure that we built yesterday incorporating the new parts described above as well as a lot of duplicates of some of the older parts:
[attachthumb=#14]  [attachthumb=#15]  [attachthumb=#16]
I still need to complete many parts built this week with auto body filler, sanding, and then either spar urethane or paint.  I hope to have that all done in the next couple of days.
28 September, 2008
Late in 2007, Alan Schwabacher on the Family Woodworking forum suggested:  "I think it would be cool if you signed and dated a board, and then have each grandchild who plays with it do the same. After a few decades it could become even more meaningful."
It took me a long time, but today I finally got around to acting upon Alan's suggestion.  First of all, I used a "branding iron" (given to me by my wife a few years ago but little used) on each piece:
[attachthumb=#1]
Next I burned the name one of my grandchildren into a log (one log for each grandchild) I am going to ask each child to pant something on their log and to sign and date it. Once they have done so, I will cover their art with spar urethane.
[attachimg=#2]
My first grandchild, Christian Frackleton, died when he was 2.5 months old and I have created a log in his memory and then painted it in a way that is appropriate for me (and, I hope, for his sisters and his parents).
I will post an update with the children's art once they have created it.
neilc said:
Great way to personalize an already fantastic project.
Add dates to it as well - they'll want to share the dates with their children!
neil
Neil, I agree and am trying to determine the best way to  add the date.  I have an electric branding iron that my wife purchased at Lee Valley with the text "HANDCRAFTED BY FRANK PELLOW" and I have used this on most of the pieces.
Lee Valley does not carry a date branding iron, but Woodcraft lists this attachment (http://www.woodcraft.com/EnhancedImage.aspx?Productid=123039&Size=Large)  that I think would fit the iron that I have.  If anyone has experience with this attachment, I would appreciate hearing from them.
Great project Frank. I see that the project has grown as the grandchildren have grown. Any plans on when the project will end? I foresee a full size cabin in the future on Pellow's Island.
My plan is that it will never end.
By the way I just counted and there are currently over 150 pieces.  I see a minimum of 300 pieces two years from now.
Looks like you'll be tearing down all the neighbor's fences for materials Frank!  ;)
Congrats on winning the sander.  Well deserved.
neil
I'm building a child's house too.
It's not the same style, but you can check for more pictures of the construction here. It's in french, but the pictures speaks for themselves.
http://www.e-studio.ch/brico/
Right now I'm finishing the roof with red cedar shingles. I will post the pictures of the construction of the roof this weekend.
Alex
You can never predict how children will play:
Recently Margaret and I babysat Melanie and Sabrina (our honourary nieces) overnight.  After our dinner, I introduced the girls to the log construction kit and they enjoyed building with it very much.  Then, the next Monday morning Melanie entertained herself for more than an hour playing with parts of the kit in a way that I never envisioned:
[attachthumb=#1]
17 October 2008:
As many of you know this project "won" the September contest.  :) My fellow designers (Isla and Ethan) and I are most appreciative of the honour.   The advertised prize was a DS 400 or RS 400 sander, but Christian told me I could substitute another tool if I wished to.  Since I already have three Festool sanders and since I recently read the great material on the MFS Multirouting Template by both Jerry Work and Brice Burrell, I decided to take the MFS 700 as our prize.  It arrived about an hour ago and I expect to be trying it out on Sunday.
Also, I promised to show pictures of the children's art once they had painted their logs.  Two weeks ago, I took the kit the my daughter Kristel's house near Ottawa where it will stay for a couple of months.   Here is a structure that the girls built where they placed the log dedicated to their deceased brother Christian in a prominent place on the wall:
[attachimg=#1]
Here are the logs finished by my grandaughters:
[attachimg=#2]
Frank,
I never saw this thread and am glad I have now. It's a story book and leaves me with a lump in my throat.
