I see lots of posts on how to join face frames to cabinets with the Domino but can't find anything about constructing the face frames themselves. Bear with me because I am a total noob.
I have rails and stiles that are 25 mm deep by 50 mm wide. I can centre the tenon in the stile using the saddle fence - that puts the centre of that mortise 25 mm from the edge. The alignment pins on the base of the Domino will put the centre of the mortise in the rail 37 mm from the edge. I would like to make both mortises at the minimal width so the tenons can draw the parts into alignment. Is there a way to make the centre of the mortise in the rail 25 mm from the edge? I know I could just draw a pencil line 25mm from the edge of the rail and use the line scribed in the clear plastic reference scale but wonder if that would be accurate enough.
Any help would be most appreciated.
