squall_line
- Feb 17, 2021
The 4" and 6" rules are both maximums, to prevent any sort of insertion or pass-through that could lead to entrapment or a fall.
Here's an example of a local building code with diagrams, that basically follows IBC:
https://www.linncountyiowa.gov/DocumentCenter/View/1285/Stairs--Railings-PDF
The "insert" seems to be what the OP is heading towards, but probably not on a triangle-by-triangle basis.
Actually, now that I think about it, I think Carpenter-Logan wants to just put the rods/wires along the face of the panel to avoid drilling through all of the dividers. They likely still need to be tacked to the body of the panel at each crossing to prevent movement.
Wire barriers have their own requirements; basically, they need to have enough tension to pass the 4" rule when stressed/stretched.
