I'm making a diamond plate holder in the style of Paul Sellers system. I'm sizing it to just fit inside a systainer but i'd like to raise it up on cleats to near the top of the systainer so I can use the space below for associated supplies.
What would be the best way to attach some cleats (maybe 3/4" x 3/4") to the sides of the systainer to hold the assembly up. It will have considerable weight as it will have three 8" x 3" DMT DiaSharp stones plus a leather strop.
I'd rather not put screws in from the outside so some sort of glue would be needed. Would CA glue be the best? Any particular version? How about epoxy (never used it before)? It would need to form a strong bond between the plastic systainer sides and the wooden cleat.
If a cleat glued to the side would not be strong enough, I could put a solid block of wood on each side all the way down to the floor of the systainer. I'd still need advice on how to glue that to the sides so it was stable.
Thanks, Mark
Thanks, Mark
