Faux wood grain finish on MDF
Hardel
Reading the discussion on filling the edges of MDF started me thinking about using that same material for a knock-down bookcase for my granddaughter bedroom.  I have tried to steer my kids away for the dark brown finishes that a popular now days to no avail.  Since I think it might have a limited life I thought the use of a less expensive material might be just the ticket.  IKEA sells tons of the stuff.  I don't have a source for a grain pattern MDF so I thought if I primed the MDF with a oil based primer then use a graining tool on either a gel stain or glazing to create the illusion of wood before sealing it with a top coat might work? I was going to try it but thought I ask just in case I've spent to much time alone in my  basement shop. Thanks.
Sounds like a fun project.  Should work!
Try a few variations on mdf scrap and see if your granddaughter likes it.  Maybe even try a few panels with interesting colors that don't particularly look like wood.
Gel stain would probably work but if it is going on top of primer or directly on the MDF I am not sure it needs to be stain. I have done something similar with latex paint.
Here is a couple threads from a professional painting forum I am on where people do some really nice faux work. I have no experience with it myself but thought maybe these pics could give you ideas.
http://www.painttalk.com/f29/fireplace-transformation-faux-wood-2035/
http://www.painttalk.com/f29/sitting-area-fireplace-mantle-graining-13277/
http://www.painttalk.com/f29/woodgrained-living-room-13033/
http://www.painttalk.com/f29/grained-front-door-17914/
The first guy no longer participates on the board and has switched his focus to foil and metal work.
The second guy Michael Tust does workshops but does not have any dvds. If you search the net I am sure you can find some good faux people that offer dvds on tips and techniques. I have seen some really good faux and some bad faux work over the years and just like with any facet of painting it takes practice of technique and materials. Good luck with your project I look forward to seeing the finished work.
