par said:t's for professional use. My work is flooring (wood flooring, laminate flooring ...) I have Virutex RZ270S and Bosch GFS 350 E and i want change BOSCH GFS 350 with Festool or Fein ... First i use Virutex for cutting, but fails to always cut ... and cut final with Bosch. It's something like for example on the photo.[attachimg=2]
This machines have blades for cutting metal? Sometimes the door frame is metal ... Thank you
promhandicam said:Perhaps after reading this thread the forum should be changed to the Fein Owners Group ;D BTW, I've also got the Fein multimaster and it's a far more versatile tool compared to the much more expensive Festool vecturo. As with all these tools though it is the blades that actually do the work and so find a cost effective supply of blades is the most important consideration.
DB10 said:promhandicam said:Perhaps after reading this thread the forum should be changed to the Fein Owners Group ;D BTW, I've also got the Fein multimaster and it's a far more versatile tool compared to the much more expensive Festool vecturo. As with all these tools though it is the blades that actually do the work and so find a cost effective supply of blades is the most important consideration.
How about the Fein & Festool Owners Group, because down here both Festool and Fein are imported in to Australia by the same company, Tooltechnic systems (TTS)
As regards to Vecturo or Supercut / Multimaster its's a no brainier down here, basic Vecturo is twice the price of a Super cut.
[member=13058]Kev[/member] there will always be an exception to the rule [smile]Kev said:DB10 said:promhandicam said:Perhaps after reading this thread the forum should be changed to the Fein Owners Group ;D BTW, I've also got the Fein multimaster and it's a far more versatile tool compared to the much more expensive Festool vecturo. As with all these tools though it is the blades that actually do the work and so find a cost effective supply of blades is the most important consideration.
[member=42735]DB10[/member]
LOL - that means I'm one of the people with no brain [crying]
DB10 said:But in your opinion is the Vecturo worth twice the cost of a Super Cut in basic form?
Whilst reading this thread I looked at the Fein Australia website and learnt Tooltechnic Systems Australia is the local importer. It was news to me...Kev said:DB10 said:But in your opinion is the Vecturo worth twice the cost of a Super Cut in basic form?
"Worth" is a hard one ... if the extra bases allow me to do one thing/job better than the Supercut - then it could be of value, but to just look at the two tools and ask the question .. probably not!
Relatively speaking, the Vecturo set is a "bargain" compared to the basic tool (when you add up the cost of the included Festool accessories and consumables @ RRP).
Retail blade prices? ... ROBBERY!! [eek]
