AlexThePalex
- Nov 12, 2008
Holz-Her said:New Fein cordless SuperCut:
The corded models will follow in january
Is that the surgeon's kit?
Alex said:Holz-Her said:New Fein cordless SuperCut:
Dovetail65 said:I could never get it to pull more than 9 or 10 amps under heavy cutting. I believe it's rated at 13 amps...
jamanjeval said:For occasional use, don't overlook the Harbor Freight ones. I think mine cost around $20 on sale; the one without the variable speed This along with inexpensive blades from Amazon doest most all of what I need from installing flooring (like the OP asked about), cutting in junction boxes, repairing doors, installing floor registers or cutting out rotted wood.
I cant say I've ever run into a situation where I needed more power. The cutting is mainly a funtion of the blades. The downsides are that it is noisy (you need to wear haring protection and should be do so anyways) and there is a good bit of vibration but not unmanageably so. Also, blade changes require the use of an allen key.
