I have an older Leigh Jig, the D-4. I have not used it for about 9 years. I decided to reacquaint myself with it this week. I had always used either my Porter Cable 690 or DeWalt 621 with it. No problems noted.
Well I tried using it with my 1400. In no way am I saying that the router was at fault, but I just need some help in determining what I was doing wrong.
The first tail board I cut was 3/4" African mahogany. I set the router speed at 6. It absolutely tore the first set of tails up. I lowered the speed to 3 and it did a little better on the second set.
I then tried cutting tails in 3/4" pine. With the router set at 6, it cut both ends of the tail board fairly well.
I know the problem is with me. I think I was somewhat apprehensive about the whole process and may have been forcing the cut. I don't think it was the sharpness of the dovetail bit since I have not used it that much. Could the type of material have contributed the this gosh awful tearout?
Unfortunately, I did not get the chance to try it again last night. Hopefully one of you experts can provide some guidance.
Thanks in advance.
Neill
Thanks in advance.
Neill
