Festool - Adapter plate for T-Lock and classic SYS
FestitaMakool
NOR
As promised, making a stand-alone thread for adapter plates for utilising T-Lock, classic SYS, 4-point and even Bott rails (Where applicable)
Festool Tool holder, WHR-CT LHS 2, part no’ 205274 was used here.
How it looks like in official photos:
Here’s it mounted on the bottom of my Raaco adoption:
[attachimg=2]
Here’s how the base looks like inside, separated from the original top.
(There’s edges all around the base that protrudes 5mm from the raised edges)
[attachimg=3]
Here’s what it look like when I received it, both top and bottom is made of hard rigid plastic.
(In the official photos it looked like the top was made of semi-hard plastic)
[attachimg=4]
Here’s showing the 3 screws the top and bottom that where holding it all together.
[attachimg=5]
Here’s the underside of the top:
[attachimg=6]
Max load T-Lock vs Classic SYS:
[attachimg=7]
To add:
Raaco apparently makes an adapter plate, I believe it’s only compatible with classic SYS.
I snatched these from the Raaco video: (Bright yellow piece)
[attachimg=2]
FestitaMakool said:
and a multi adaptor that is compatible with:
Suitable for Metabo MetaLOC, Systainer Classic/T-LOC, Hikoki HIK-System, Makita MAKPAC, Sortimo/Bosch L-BOXX and Dewalt T-STAK. No less…
Where’s Festool??? …
It's right there, after MetaLOC, IMO.  Festool specifically calls their cases by their original name: Systainer.  They didn't come up with their own model name or even their own variation of the original the way Makita and Hikoki did with MAKPAC or HIK-System.
Oh, I meant; where’s the Festool variant of an adapter.. [wink]
[member=71478]FestitaMakool[/member] I've been looking forward to you posting this thread, thanks for following up and giving such a detailed post.
I'm ordering 1 or 2 next week, I'm thinking about cutting away the inner plastic bits of the bottom part and attaching a piece wood to it and making it an MFT.  Yes it would always have to be on the top of a stack of systainers but I'm ok with that.
What are your other ideas for using this adapter plate?
In the last thread I said I was waiting for Festool to get back to me to see if the bottom part was available on it's own, I still haven't heard back from them yet.  If I do I'll post it in this thread.
Thank you again
