sicd_steve
- Feb 26, 2013
Guys I have nearly all the Festool products......and in the most love them!
The one i hate most of all is the " idiot" at Festool who designed the connector that fits on the belt sander to take the suction hose. This damn thing keeps coming loose and falling off because it can't lock properly as a result of very poor design .
The unit twists a half turn to so cAlled lock position then when you have to use the vac hose 27mm the action of sanding makes the whole unit undo and fall off.....the hose fits perfect but this half turn elbow unit is nothing but poorly thought out design.
It should. Have been a screw tight thread so you can properly lock it to the sander and it woul be perfect as the action of sanding up and down puts pressure on the hose which sticks up and I using a boom arm as well it is much worse without a boom arm as the pressure on the hose connection is much greater.
Other than gluing it to a $1000 sander has anyone else had this problem and if so how did they resolve it?
Thanks guys
Thanks guys
