Hi Guys,
I'm considering buying the Boom Arm for the CT 26. I have a basement shop where head room is an issue if the boom arm is 7' high from floor level. I have only 80 inches clearance under two steel beams in my basement so that moving the CT with boom arm around the basement would be problematic. If the boom arm would be 4 inches shorter, i.e., instead of 7' high it could be reduced to 6'8", problem would be solved. I had a look at the boom arm assembly at Lee Valley here in Ottawa and it appears feasible to cut 4" from the vertical tube where it meets the base of the CT. Anyone have/had a similar problem? Is it possible to do as I suggest?
Cheers,
Denny
Cheers,
Denny
