Festool Centrotec Chuck in a non-festool drill
sanjay
Hi Everyone,
I have done lots of research online already but thought i would double-check just incase.  I have the Milwaukee M12 install tool which i really like and lots of other milwaukee / dewalt drivers and drills. I would like to use the centrotec bits until i can swap out my drills to festool.  I can buy the chuck but noticed the 1/4" adapter does not have any indents, so it wont lock into any of my drills until i use drill chuck.  Does anyone know if there is an aftermarket adapter that exists for the festool chuck that does lock into standard 1/4" drivers?
In addition, is the FESTOOL 576931 SYS3 ORG M89 CE-M. a good kit to start with?  I do mainly DIY and cabinetry work
george,
Thank you. i already had links to both these items.  My question was not where i can buy them, but if there is a solution that allows for the chuck to lock into a non-festool 1/4" driver.
So you want to put a Festool Centrotec chuck onto a different drill (as in power unit) brand? If so, the answer is no. Nothing I know of exists to do that.
Sanjay- Are you sure you need an adapter?  My Bosch PS21 and PS22 work just fine with Centrotec bits, no adapter needed.  I don't know if that's the case for Milwaukee and DW, but if you haven't tried yet, you might get a pleasant surprise.
Beyond that, the only adapter I know of is probably the same one you've seen- and it's not even 1/4" on the drill end, it's 5/16".
sanjay said:
Hi Everyone,
Any way you slice it - it will be over the top complicated.
Your best bet is swap the M12 for a CXS instead of investing in the bits set and then get the bits later one. Pretty sure you can resell the M12 driver or keep it for specific tasks - never enough drivers on a job!
I made the mistake of buying the adaptor assuming it would fit a 1/4 inch driver then discovering it's bigger. So it sits in my case of centrotec bits unused. If I had a welder and the welding skills and was looking for something to do, I'd probably cut off the socket and weld it onto a 1/4 hex shaft.
If it's bigger you should be able to grind it down to size?
That's certainly possible, but I don't have a way of doing that  accurately and being able to use Centrotec bits in my 1/4" driver isn't enough of an advantage to justify the effort of doing it well. Actually, the same is true of welding it too, even if I had the gear.
Back when I bought it I thought it would make sense to "standardize" with centrotec bits, but I've come to a different conclusion. I have a few Centrotec drill bits that I use with the Festool drill in it's quick change chuck, I can chuck those same bits in my non-Festool drill's Jacobs chuck if I need, and there is little reason to put them on an impact driver.
For screw bits, short ones aren't Centrotec-specific, and I can substitute for the longer ones if I am using my impact driver.
It's interesting that the Bosch driver may accept both however.
The centrotec adapter seems to fit in the Milwaukee M12 installation driver chuck attachment. It’s a bit long but it works.
Wera "Rapidaptors" have a detent to allow locking into hex chucks (like the M12) and it then locks in Centrotec bits as well as your normal 25mm+ wire bits. I use them on most of my drills as they take the pain out of getting a bit in without having to think about the chuck.
Roachmill said:
. They're not as fancy as the Wera ones but they are considerably cheaper, rated for impact duties and come in a range of lengths from 73mm up to 305mm.
i had one for my old makita dtd152.  and it didnt like it.  it exploded.  i now use these absolutely rock solid, doesn't lock in the holder, but only left the bit in 1 or 2 times.  and there shorter and cheeper.  nothing to go wrong with them either ;)
https://www.bigredpowertools.co.uk/milwaukee-4932352406
and i have been useing that on by DTD154, which is an altogether more powerful beast
