MrToolJunkie
- Jul 6, 2009
You can get this bit from several retailers - might not be in stock everywhere, but this is the part number:
Festool 492524
Festool 492524
John Huh said:I also wish the 4.5mm countersink bit (492524 ) comes with this kit. Drill bit with depth stop (492522) is included however.
contendernut said:The 5mm is depth stop not countersink. Not suppose to have a countersink. It’s more along lines of shelf pin hole type drill bit. It drills a flat bottomed hole
https://www.festool.com/accessory/496451---bsta-hs-d-5-ce#Overviewneeleman said:Pictures on Amazon are not correct.
pictures 4.5 and 5.0 have been swapped
better look at Festool websites
correct naming is BSTA 3.5 and BSTA 4.5 and BTA 5.0 (no sink)
Alex said:I would really like to see a BSTA 2.5 too. 3, 4 and 5 mm screws is what I use most.
ScotF said:Snappy makes some good stuff - they also make a 3/8 inch insert you can use with large bits beyond 1/4 (as long as the shank is 3/8).
Seth - are you saying Snappy makes metric bits?
