ryanjg117
- May 18, 2015
The boom arm on my CT36 recently started swinging uncontrollably and I identified the problem - the boom arm tube slides into a slot/recess in the plastic dust fitting holder at the bottom of the vac. Somehow the tabs inside this slot/recess which keep the tube from rotating had caved in. Doesn't seem like a very robustly designed solution as the boom arm carries a lot of weight and the plastic tabs inside the tool holders are tiny. Anyway.
We found an easy solution: move the boom arm to the opposite side recess/slot. I can't believe I didn't think of this. (The boom arm can be mounted in either the 1st or 4th tool holder position.) Problem solved, but...
Before we discovered this solution, E from Festool Support noted the Boom Arm Handle (495802) is considered a "consumable" and, like other consumables such as abrasives, are not covered under the standard Festool warranty. I had a tough time digesting that a fairly rugged handle, part of the $390 boom arm kit, would be considered a temporary item in need of frequent replacement.
Has anyone experienced any surprise "that's a consumable" responses from Festool?
