T said:
That's a bummer - I had hoped that the latest UJK
version was being produced in-house in Axminster (or wherever the U.K.-made UJK items are being produced). That changes my perception of the UJK version.
Since you've pointed out that the UJK version is a Taiwanese product this fact likely explains the long hiatus between Version 1 and Version 2 - they were relying on a third party half a world away to produce the product (with all the attendant problems this kind of reliance often creates).
It bears pointing out that the current UJK version has some unique features not evident in the no-frills version that you stumbled upon. Anodizing color choice aside, the current UJK version appears to have a much more thought-out interface (even from Version 1's) between the frame that holds the chuck and the guide rods it slides up and down on. The UJK-version utilizes "Oilite bronze bushes" (or "bushings" for those of us on the other side of the Atlantic) while, at least from what is evident in the images and description, the no-frills version does not:
[attachimg=2]
I would pass on the no-frills version for this reason alone. The lack of precision in this area is what plagues most drill stands of this type (and what likely makes the UJK version stand out from all the rest) - and based on another forum member's disappointing
review I include the Kanzawa offerings in this category also.
Meanwhile, while both versions feature what appears to be the same "rubberised high friction pad" on the underside of the stand, their respective chuck capacity is different. The no-frills version features a 9.5mm chuck while the UJK version features a full 10mm chuck. That said, they both feature a Centrotec-compatible hex shank (which is the feature that confirmed for me at least the Tawianese provenance of the UJK-branded stand).
Speaking of which,
here's the page on the manufacturer's (Fortune Extendables Corp.'s) website that details the no-frills version. Their description for the two versions they sell under their own name (one shorter, one taller) mentions the availability of different sized chucks which might explain why the UJK version has one size chuck and the no-frills version (at least the stock version) has another.
Other notable differences include the rubber protective guide rod covers (which the UJK sports while the no-frills does not) and, most curiously, the fact that the UJK version features four mounting slots designed to accept mounting of the UJK "Self Centring [sic]
Vice [sic] for Drill Guide", a potentially game-changing accessory that, before now, I was totally unaware of:
A quick scan of the Fortune website produces what is no doubt the
inspiration behind the UJK drill stand vise (which I'm going to guess is also being produced for UJK by Fortune).
As an aside, I also note that Fortune makes another cheaper-looking
drill stand.
Wrapping it up, that the current UJK-branded drill-stand has no allowance for dust collection likely results from the fact that Axminster is relying on an existing design produced by a third party (who really missed the boat on this aspect). Too bad, really, especially since - as I've pointed out
elsewhere in this thread - if the
cheapest of the cheap can feature integrated dust collection:
=youtu.be
...then why can't what might arguably be 'the best of the best' also feature it?
[member=63423]AxminsterTools[/member] are you listening?
Finally, since the current version of the UJK drill stand is now available for sale on the Axminster site, I guess that means that it should be any day now that TSO gets them in stock. I wonder, [member=59331]TSO Products[/member], have you elected to offer the vise as well?
If the bushings work as advertised (to vastly improve this stand's precision over all other's in the marketplace) I might have to take the plunge and pick up both of these items. Having myself long considered a Wabeco drill stand I've decided recently (based upon a far-too-long term examination what I tend to require) that I will be best served by a far more portable and store'able 'mini' drill stand (the UJK-branded version being specifically what I'm after).
