MikeCalifornia said:
Is the ETS not what I think a random orbital is? I have a rigid sander that spins pretty fast on high. This seems to spin much slower, but use more vibration to sand. I do alot of vertical stuff, doors, cabinets, etc.
It is nowhere near as aggressive as other random orbit sanders. It is a finish sander used primarily for between coat work. It will remove wood and finishes, but that is not its primary purpose.
When the unit is held in the air there is very little motion, place it on a surface the motion increases. If this does not happen the extractor is set to high or to much hand pressure.
As others have mentioned the RO 125 may suit your needs better, it has a 5 mm stroke in the RO mode (the ETS 125 is 2 mm). The ETS 150-5 may also be a better fit for your needs, it will act more like your Rigid sander.
