Festool Extraction Hose Diameters
samsmith93
I recently purchased a CTL MIDI.
I am looking at hose options for different bits and bobs. I keep reading about the D27 hose, but I think this actually has an OD of 36mm.
Does anyone know the following info about the hoses:
- D27 hose outer diameter (of the hose itself, not the nozzle)
- D27 hose inner diameter
- D36 hose outer diameter
- D36 hose inner diameter
Thanks!
As an info starting point .................. The 'D' sizes ( D27, etc) are the inside diameter of the hose in millimeters. The ID and OD diameters of the hose end fittings vary from that size depending on whether or not they are designed to fit into ports, over ports, or connect to other hose end fittings (or both / all three).
