Sparktrician
- Dec 4, 2009
There has been chatter recently regarding choices to use long rails or to use shorter rails joined together and the inherent issues in assuring that joined rails remain straight and true. Several months ago, some one of the FOGgers mentioned finding a great substitute screw to use in the rail connectors. It's stainless steel with a nylon tip, available from McMaster-Carr, part number 93285A412 at $9.54 for a pack of five, including a 3mm hex driver which can be used in a standard 1/4" hex drive. The photos attached show the standard connector screw beside the nylon-tipped replacement, plus the actual package they come in. YMMV.
Edit, 12/27/13: These screws do NOT come with the hex wrench. My bad.
