Festool Kapex 120 miter saw
fernando68
For sale is a used Festool Kapex 120 miter saw.
The saw is used but works great. The lasers are a little weak, I am not sure if there is an adjustemnt for them.
Every aspect of the Kapex KS 120 Miter Saw is engineered for accuracy, convenience and capacity. The forward rail design allows operation right up against a wall or in tight hallways, while the front-mounted bevel adjustment means you'll never to reach awkwardly behind the saw for the lock knob. The bevel adjustment is precisely counterbalanced, with smooth knob actuation so the saw won't suddenly fall to 45° under its own weight. Dual lasers show you exactly where the kerf will fall for cuts on either the left or right of the blade. Variable speed lets you fine-tune the cut characteristics for various materials. The Kapex also features a special cutting position that uses the back of the blade to cut taller pieces than usual—perfect for baseboard molding up to 4-3/4'' tall. Like all Festool products, dust collection is carefully integrated, using a chip deflector that efficiently funnels dust into the port.
Features:
Light in weight, heavy in features
Effective dust extraction, precise cuts, easy adjustments, and quality components
Rail forward design creates a compact footprint while preventing head play for accurate cuts
Easily align cuts on the left or right with the dual lasers, which clearly define the kerf
Micro-adjustable bevel angle with up-front rotary knob
Large bevel scale and fine pointers make it easy to set precise angles
Dust extraction up to 91% with behind-the-cut dust hood and pivoting 36mm hose
$799 O.B.O.
Located in the Boston area. I prefer local pick up but I am willing to ship.
