Hi. I have the Festool Midi vacuum cleaner, the new version.
I also have CMS with TS55.
I also have 497702, which comes with a long hose.
I have thought about buying Cyclone CT Festool.
To connect CMS, with the Festool CT Cyclone, do I need the Festool CS 70 AB 488292, or could I use the hose from 497702 and the one from the vacuum cleaner, adding 50 SV-AS / D 50 V 452898?
How would I have a better aspiration, what interests me the most?
I have seen that in the MIDI vacuum cleaner, it cannot be connected directly, another adapter is needed (festool 499196), but if you connect directly to the Ct cyclone I suppose that adapter is no longer needed.
What is the best?
I buy the CT Cyclone and 452898 and use the hoses that I have or do I buy the cyclone with the Festool CS 70 AB 488292? Thank you.
What is the best?
