- Sep 21, 2022
This Spring, Festool is increasing their selection of cordless tools and accessories in a big way. Included in the release are a cordless sliding compound mitre saw with full range of accessories, a larger cordless dust extractor, and improved DTS and DTSC sanding pads.
The new sanding pads feature an extra two holes near the back to reduce suction between the sander and workpiece so movement of the sander and surface finish is better. This is a rolling change and the new cordless DTSC sanders are available now. Pads, pad protectors, and abrasives are forwards and backwards compatible.
Also, the TS 75 will be available again starting March 21 and we strongly recommend pre-ordering as supply is still limited. For other tools, you can put your name on the waitlist to be notified when stock arrives.
Check out what's new
