Ajax said:
Gimmicky?
Oh the lengths people will go to in order to defend Festool.
No, not at all. It's just that I don't agree that it needs one. Like you, I'm entitled to my opinion, that's all.
Ajax said:
Anyhow, doesn't the new Carvex have some "gimmicky" LED lighting?
Extra light means more safety IMO. Nothing gimmicky about that.
You're not comparing apples with apples, a jigsaw is totally different. With a jigsaw, it's completely guided by hand, and you need to see where the cutting edge is. Also a jigsaw is often used in a situation where the ambient light isn't great. Having said that, I usually cut from underneath anyway, so I have the lights turned off on mine.
With a router, you're working with a collar, or a bearing, against a template, or a straightedge, or
something that's guiding exactly where the cutting edge is going. Usually somewhere with decent lighting. If you can't see where you're going with a router, then you shouldn't really be using it. When I'm using a router it's very rare that I'm actually looking at the bit itself, I'm usually looking ahead of the router to see where I'm going, or at the rail/fence/straightedge or whatever to make sure the router is tight up against it. The only time I look directly at the cutting bit is when I'm setting it up.
Besides, complaining that the OF1400 doesn't have an LED light is like complaining that your 10 year old car doesn't have Bluetooth. Sure, it might have been possible at the time it was designed, but it would have been extremely expensive to incorporate into the design.
