afish said:
if you have a cnc, then I would say you might be better off with several small cordless trim routers. I do most of my cutting on cnc and I have 6 cordless dewalt trim routers so i dont need to change bits very often. these 6 routers handle 95% of what I need. My MFK only comes out for trimming real wood edge banding or laminate edge banding. I have a few larger 1/2 routers but I cant even remember the last time I touched one.
afish, I have seen your name many times, but I'm failing to remember what it is that you do? Hobbyist, pro woodworker, fitter/installer, etc. I don't know if I have missed it, or you have just never indicated?
I mention this because of the multiple router comment, which leads me to pro in some capacity.
I do the same, but I just don't see most hobby woodworkers or makers seeing the value?
Even here I have seen guys who fall into the "one" router thinking?
To the original question: This falls into the horrible answer of "it depends". If all you need to do is trim tabs from cnc parts, the much cheaper Makita compact router is fine. It will do the job all day long. The cordless version is quite handy and everything is compatible between the corded and cordless. The size and volume of the parts you cut may have some influence in this though.
If you do smaller parts it might be better to trim the tabs on a router table. It's all about size ratio. Big parts, bring the tool to the parts and with small parts, bring the part to the tool.
The Makita will also fill all of your edge profile needs too. There are also plunge, tilt, and off-set bases available for it.
The Festool offerings will do all of this too. The MFK700 has the horizontal base that adds much more utility as well as very good dust collection. It however lacks the plunge feature. You would need to go to the OF1010 to get both plunge and horizontal trimming.
