Leeostler182
- Jun 25, 2016
Anyone having a problem with there quadrive drill pdc18/4, I cant select a desired gear without battling with the drill there's all sorts of grinding noises on gear 1 when changing gear the switch ends up going between numbers 3-4 and 2-3 I've tryed pressing trigger between shift works sometimes.also when u lift the drill upside down and press the trigger the sound slightly changes asif the gears aren't properly engaged there's grease coming out of drill onto selection switch it's really frustrating as the drill hasn't been used that much would appreciate feedback thank you
