idratherplaytennis
- Jul 6, 2015
I just purchased the TID/TPC set yesterday and went out to play with it and see what kind of things I could expect. I do remodeling/repair/woodwork/jack of most trades sort of work with my tools, and I have plenty of alternatives and things to compare with.. but I'm looking mostly for perspective from existing or current owners of the Quadrive who are familiar with it's power.
I purchased the TPC mostly as an upgrade to my T18+3 which I love for the smoothness and versatility, however I've always gone towards my trusty burly Makita when I need actual speed and torque. Now- I know Festool drills aren't known for their torque compared to the contractor drills Makita, Dewalt, Bosch, Milwaukee throw out there, however at the same time, my first test was exceptionally disappointing. I clamped a piece of exceptionally dry 2x4 doug fir to my vise, and tested through it with a 1" Irwin SpeedBor bit seen here on Lowe's website. My Makita shot through on it's high speed gear, lower torque setting (no load speed 2100 rpm, couldn't find the torque value for high speed). The Festool stopped 1-2 mm in on both gears 4 and 3 (3600 and 2350 rpm, respectively) but went through with no issue at gear 2 (800rpm).
Now.. the real question I have is, what should I expect? Is this auger-style bit not meant for running at high speeds? I found a spot on FestoolUSA's spot for the TPC that specifically states under product details: "4th gear: Quick drilling with medium and small drill bits up to 1-3/8" (35 mm), for example Forstner drill bits." If you look at this linked bit from Lowe's website, the only glaring difference between this and a forstner bit is that forstner bits don't have the self-feeding screw tip. Maybe that's the issue, maybe not, but I can see a much bigger 1-3/8" forstner bit stalling out with just as much pressure as I would think this 1" self feed does. Am I expecting too much? There's a lot of video reviews of them chugging through massive timber on foot long auger bits in one go on what I would normally assume is the lower gear settings, however there's a lot touting it's speed. Yes- this drill is super smooth, and at least with my T18+3, I have come to truly appreciate it's delicate clutch settings when driving screws for reliably stopping where it should (I've never had a non-festool drill with a good clutch to stop reliably in the same spot time after time), however I would like to know if I either an expecting too much or if this sounds like the drill stopping this quickly into a dry 2x4 is a manufacturing defect, that it should power through.
I did ensure I had the drill set to drill (not percussion) and the dial was set on the drill icon, not any of the clutch settings. While not a 100% dealbreaker for me on this drill, I would very much like to know if it's underperforming. For the price I paid, I definitely got the smoothness I came to expect from Festool, but I am about 90% sure even my T18+3 on it's higher speed would drill through the 2x4.. in fact (goes outside), in fact yes. My T18+3 that I purchased 2-3 years ago blasts through just fine on high gear 2. Upon reviewing the manual, it is stopping with a single beep and no flashing indicator lights signaling that it's overloaded and not being triggered by the kickback stop feature (which should have indicator lights). I don't see any world where the higher end drill that should be fine with a 1-3/8 forstner bit on gear 4 is outperformed by it's much older and less expensive little brother.. (only difference was original testing was with a new 4ah fully charged battery on the TPC and a not so fully charged 5.0 on the T18, however the results were the same upon trying with the same batteries).
Any advice and insights into these drills would be greatly appreciated- whether it seems like a fluke, or maybe I need to return the drill to try out another and see if it's a defect. Thanks for your time and input.
