bonesbr549
- Jan 1, 2008
Here me out, I've got a project that I'm wondering if the festool power planer will solve an issue. I'm working on an 8 sided cherry pencil post bed. Post is 80" long 2 5/8" square. The taper will begin at 26" from the floor and reduce down to 1 1/4" at the top. The challenge is cutting the taper. I've resarched and I've seen everything from a taper jig on a Table saw, to spoke shave and hand planes. I could do it with TS, but I'd prefer not to hoss that big a post through the blade with a taper jig. The hand plane could do it, but I got to thinking rig up two rails' with the power planer riding on top and pivot the post upward and use the power planer to shave off the facet to get the 4 sided taper needed. For the next 4 facets that are cut at 45 degree to those make a cradel that is a 45 to pivot the post and repeat. Just thinking out of the box. Am I crazy, or do I just secretly want an excuse to tell the wife that to finish the bed, I need the tool (worked with the kapex and the hutch
