impecunious
- Oct 31, 2015
Hi guys,
So I installed my first patio door interior casing this past week in a "Classical Craftsman" style, complete with 3.25" side casing and a 3.5" frieze that's sandwiched & recessed between a bead and a cornice. I'm planning to eventually redo the interior trim in all the house with this same style, so I'm trying to learn what I can from this test case in terms of what gear will make life easier for future installs.
Thinking that the combination of the RTS 400 small rectangular sander and the new CT SYS vac would be perfect for prepping my trim after installation and prior to final paint, I ordered this combination earlier this week and gave it a shot today. The footprint of the RTS 400 is absolutely perfect as I expected for my side casing & frieze. However, I ran into a bit of a problem...
Every time I tried to touch the sander flush to the frieze, it skipped around like it was on crack or something. I ended up having to carefully sand my filled nail holes with just the front edge of the sander, taking care to avoid setting the entire sander flush on the wood. And although I had an easier time sanding the side casing, I could only do so with the sander straddling the casing perpendicular, and moving the sander like this up and down. If I tried to orient it long-ways with the casing, it would skip around like with the frieze.
I've never used a true orbital sander before, but I would assume I should be able to move this sander around in any direction without a problem. Thus, (and I almost hate to ask, but) is it possible that my new CT SYS is pulling too much vacuum for the sander to actually sand properly? Unlike the normal CT vacs, there doesn't seem to be a way to dial down the suction on the CT SYS, so if this is the problem I would really hate to have to return this neat setup back to the store.
