ear3
I've started using Surfix for finishing, and have been pleased so far with the results. Previously I was using the heavy oil, but when I had to reup on my bottles the other day, I ended up getting the One-Step instead, since that was the only one my dealer had in stock at the moment.
The basic application instructions for the one-step appear to be identical to the heavy oil, but because the one step has wax added in, the 320 grit abrasive I use to sand in between coats loads up almost immediately (unlike the heavy oil, where a single sheet will usually do the trick). I'm struggling to see how it could be otherwise, since wax will always wreak havoc on abrasives, and I'm wondering if you're just supposed to dispense with the intermediate sanding stage when using the one step oil.
