jmbfestool
denvertoolguy said:jmbfestool said:jvsteenb said:As interesting as it may seem to have tools share batteries - in a Festool setting I can hardly see the big advantage. Each tool comes in it's own systainer, and sports two batteries. You only need one of the chargers, for they're universal ( and THAT'S handy ). And in some cases it might even be worth it to leave one of the chargers at home, you'll have more room for bitsets/and/or sawblades or other utensils.
But I have never drained a battery in less then the time it takes to charge the other one. So in effect each systainer carries it's own self-sufficient powerplant and there would seldom be the need to swap batteries between tools.
IMHO it's wise to buy the tool that you think will perform best for you, regardless of battery type.
In fact I chose the T15+3 while I was already envisioning a Protool Duradrive with the 12+3 battery in my future. I frequently use holesaws and the extra power vs. the T12+3 was of more importance to me. If the T18+3 had been available, I might have opted for that one.
Regards,
Job
With Circular saw and jigsaw you can easily drain a battery before the other is charges trust me I can drain 3 before one is charged you would properly say I should get a corded out but hey being lazy! Any way I do agree with the drill though I do not drain the battery on the drill before the other is charged I have yet to try out my carvex with the battery because the UK still hasnt got them and I have paid full money like a month ago so I have been out of pocket for no reason could of had some interest on that!
even so the festool batteries seem to charge pretty fast compared to other brands
I dont think I agree with the Charging festool isn't that fast but they do last along time much longer than any battery brand I have used (Bosch, Milwueakee, Ryobi, Makita, Dewalt).BUT! I think its also because of the drill why the batterie lasts alot longer because it a brushless moter and instead of being just a standard trigger it has a chip inside to regulate the current and it doenst spark when you make connection or whatever its alot more efficient so the batterie lasts longer.
Well Im going to do a test with the M18 milwueakee and Festool T15 batteries!!! ill time them
