festool table saw
lordinteriors
hi guys havent posted for a while and thinking of buying a new table saw
can someone make it clear on my options i need to know what e and eb means at the end of for example (cs 70 eb)
by the way im looking at one of the pull through saws any pros or cons on these
lee
hey guys been trawling through finding out what the e and eb means and im guessing it is an electronic brake
so on to my next question does anyone have any experience with these saws i would love to hear from you with pics vids and reviews
thanks in advance
lee
Lee, is it a portable table saw or a stationary machine you are looking at.  In my workshop i use a Kitty 619 which has been a tremendous workhorse but i do plan on upgrading to a 7 series Felder next year.  On site i get by very well with the ts55 & rails.  Friends of mine use a folding Metabo & seem pleased with them but i suppose it depends what you will be using it for.
Woodguy.
Since the Precisio CS50 and CS70 saws aren't available in the USA, you won't find too much information on them, however there are a few European and Australian members who have one and who may be able to help out.
The E suffix indicates that an item has electronics with adjustable speeds. The electronics in the Precisios are MMC (Modern Multi-Material Control) electronics, which give adjustable and constant speeds, plus temperature control.
The B suffix indicates that it has a Quick-action brake, in this case for the saw blade. For some reason, 110V machines in the UK often come without quick-action brakes., and therefore omit the B suffix.
The most immediate "con" with them, and the one which puts most people off, is naturally the price. A fully kitted-out CS 70 EB-Set GB 240V (Order No 561253) retails at 1926.25 GBP, which is the almost exactly the price of two KS120 Kapex saws (without table or extensions)!
For new FOG members who have never seon one, here's what that particular saw looks like:
However, for all that money you get 70mm cutting depth at 90 degrees, easily attachable extension tables for the rear and right-hand side, a small sliding table on the left, a rip fence with micro-adjustment, an Angle Stop (similar to the one you get with the MFT/3), two blades, dual dust hose, and other bits and pieces. Getting the "Set" over the plain CS50 or CS70 does save money compared to buying the base machine and adding all the bits, so it's worth getting if you are after all the accessories.
You also get a very well-made machine that oozes quality. They are specially made for easily moving from A to B, and you are paying for that portability - the legs fold, and you can carry the saws up a flight of stairs yourself.
The extensions and sliding table have adjustments to make them co-planer with the main table and for tilt, and once you've adjusted them, they can be attached and detached very quickly without losing that adjustment. The sliding table for the CS50 is silky smooth, and I imagine the ones for the CS70 are similar (there's a choice of two).
The pull-action of the blade is unusual, but comes into its own when cross-cutting long narrow pieces. Instead of trying to move the material over the blade, you keep the material still (probably supported by a stand and perhaps clamped to the table), and then move the sawblade towards you. It therefore acts like an upside down sliding compound mitre saw.
The 1200W CS50 might well be a bit underpowered for your needs, and with 50mm cutting depth it might leave you struggling with thicker pieces. The thermal cut-out for the motor also has a reputation for cutting out too early, however it is 19.5kg compared to the 34.5kg of the 2200W CS70.
These soft-start saws are nice and quiet, which is often a consideration in residential work, and the speed can be dialled down to make them even quieter. Dust is collected from above and below the blade, and the riving knife can be lowered without tools so that it's below the top of the blade when cutting grooves etc.
As to competition in this sector, Mafell make the Erika Pull-Push Saw, and the picture below shows the 32kg 72mm capacity ERIKA 70 E:
However the price that this dealer quotes for that machine (1945.66 GBP incl VAT) doesn't seem to include the accessories shown, and if that's the case, it would make it more expensive than the comparable Festool offering!   [eek]
Forrest
WarnerConstCo. said:
Man those are cool!! [cool]
I agree.  I don't know whether or not I would purchase one, but I certainly would like the opportunity to make such a decision.
Of course, another option (again not available to North American buyers at the moment) is to go down the CMS route, and buy the CMS-GE leg stand and use one of Festool's standard plunge saws in the relevant module. This can be particularly attractive if you have a two saws, perhaps a TS55 and TS75, since you can leave one (probably the TS75) in the module almost permanently and use the other with the guiderail. If you also buy a router module, you can then use the same leg stand and one of your existing routers to make a portable router table. And then there are belt sanding and jigsaw modules too!
One disadvantage when comparing the CMS setup to the dedicated CS50 and CS70 machines is that the CMS does not have a sliding saw capability when used with the TS55 or TS75 modules - the saws are fixed, so you'd need the sliding table to do crosscuts.
Here's the CMS-TS 55-Set GB 240V which is sold as a complete unit for 982 GBP (about the same price as one Kapex without table or extensions). It mainly consists of the TS55 saw, module for the TS55, leg stand, sliding table, and Angle Stop.
Note that the CS50 and CMS share a large number of accessories, eg extension tables and rip fences etc.
Some links:
CMS Brochure
CS50 Brochure (there doesn't seem to be one for the CS70)
CS70 Video (in Italian!):
Forrest Anderson said:
As to competition in this sector, Mafell make the Erika Pull-Push Saw, and the picture below shows the 32kg 72mm capacity ERIKA 70 E: ...
Don't know if it's a direct competitor, but Metabo also do the Flexo 500 - here
Video (in German)below:-
here
Never seen one in the flesh though...
Cheers, Pete.
thanks for the replies guys im kind of leaning towards the cs 70 for cut capacity but am still looking to here from people with either of these saws
lee
Yes, I'd say it's a direct competitor, and it has lots of similarities to the Festool Precisio tablesaws. Note how you can get a Metabo table attachment, which is just like the Festool MFT/3-VL that takes CMS modules for router, jigsaw etc.
Since we're into videos, here is a two-part one entitled "Lintera Mafell demonstration in Lithuania, Jonava", which shows lots of interesting Mafell kit being demonstrated, including the DD40 DuoDoweller, Erika 85Ec table saw, portable bandsaw, Carpenter's Saw (a portable chainsaw for cutting beams), various tracksaws, BST Drilling Station (a large portable vertical drill stand), LS Chain Mortiser etc.
There's no voice soundtrack (just music), but the quality of the video is very good.
Forrest
I have a cs70 for about 6 years now, and I still like it. Originally I bought the basic version with the dust extraction set and a while later I got most of the accessories of the set version, except for the sliding table. (if I have to cut stuff that's too wide for the slide action, I prefer using the ts55) When I ordered the side extension, the rear table and the ripfence, the dealer threw in the transportwheel set.
Main advantage I see over the alternatives is the "system", I have a mft3 and the kapex (set version). You can use the fence of the mft with the little flip stop on the CS aswell, you can use the festool rail clamps in the groove in the table and the extension wings for the kapex are compatible aswell (they were originally an accesory for the CS, only difference is that the tapemeasure starts at a higher number because of the fence on the kapex, and the legs are slightly longer)
Forrest, thanks for posting the mafell clips, I've seen a few demonstrations of their stuff in person,
I really liked the KSS saws, that have a swinging blade guard so they can be set to a fixed depth, but also have a plunge lever and a spring loaded riving knife for crosscuts. They also have a crosscutting system for those saws, that's also briefly shown in the first video, it consist of a short rail that attaches to the saw, with stop blocks underneath, which can be set for square cus of angled cuts, at the start of the rail there's room for the swinging blade guard to close, and the saw returns to the start of the rail with a spring. The flexible rail that fits in the systainer with the saw also looked interesting, but I tried sliding the saw back and forth on it, and the guidance isn't that good as with a solid rail.
I 've seen the microsite for their new jigsaw, but hadn't seen it in action yet.
Here's an older topic about the cs70.
