Phil Beckley
- Oct 24, 2014
Hi
Easy test........... [wink]
Cut along the grain on solid timber with a 48t blade with a guide rail.............swap out for the 28t blade then make the same cut ...........let me know how it 'feels'..... [big grin]
You should be able to reduce the speed of the saw as well to 4-5 with the 28t blade and achieve a great cut quality.....what you will most likely feel is the TS55 'flowing' through the timber and not slowing down - correct blade for application.
By the way I am not an expert on angles, bevels, pitch, blade material, expansion slots etc.... but this is based on commercial work.
rg
Phil
rg
Phil
