FESTOP - Festool Router Table by WoodWerks
ForumMFG
A while back I had posted about a Festool supplier working on a router table of it's own similar to Steve's.  Well, it's out now.  It's called "Festop" and it retails at $279.  Looks like a pretty good setup, let me know what you guys think.  I am going to go down to woodwerks here soon to check it out.
You can view this router table HERE
Interesting!!
Seems great for smaller type shops. I wonder how much heavier the MFT becomes with the new, thicker, top.
From a personal workflow standpoint, my cutting operations usually take me from the MFT to the router table. I would not like to constantly have to swap the router setup in order to use the MFT.
I wasn't able to determine if there is any type of router lift mechanism with the setup.
Rey
Rey Johnson said:
Interesting!!
From a personal workflow standpoint, my cutting operations usually take me from the MFT to the router table. I would like to constantly have to swap the router setup in order to use the MFT.
Rey
It includes an insert, see below what it includes, from their website, I'll bet a lift could be used without any issues.  I'm with you, I prefer a dedicated router table, although if you needed a router table for on-site work this would be a good option.
The other problem I can think of is that the Kapex height when on the MFT/Kapex matches the MFT 3 height. It seems the thicker MDF would make the MFT 3 too high to function as a support for lumber being cut on the Kapex.
The 1" top has a 1/4" rebate around the bottom edge, so it sits at exactly the same height as a 3/4" top.
My version has enough room to cut most rail/style length without lowering the bit below the top
