Tom Bellemare said:Yes, I can. I'm about to order them from Italy and it'll take about 4-5 weeks.
Tom Bellemare said:Last time, the TS 75 blade was the same, oddly. I'll find out on Monday. I see no reason it wouldn't slice right through 1/2" Hardi.
Paul G said:Tom Bellemare said:Yes, I can. I'm about to order them from Italy and it'll take about 4-5 weeks.
What's the cost for the TS75 blade? And just to be sure, is it appropriate for 1/2" Hardibacker?
Tom Bellemare said:The blade for the TS 75 is the same as the one for the TS 55 - $92.50. I have some of each on order and expect to receive them in a month or so.
Bark said:I would also love to buy a blade for the ts 55. Let me know if you have extras. Thanks. Are these blades a good replacement for the hardie blades with quality of cut for siding purposes?
The hardie blade is a 4 tooth blade as well with great results. But with using the ts55 with dust extraction will make life so much better while cutting cement board siding by not having to worry about wearing a good dust mask for the dust since it is possibly cancer causing.tjbnwi said:Bark said:I would also love to buy a blade for the ts 55. Let me know if you have extras. Thanks. Are these blades a good replacement for the hardie blades with quality of cut for siding purposes?
I've never used a Hardie blade. These cut very well and as clean as can be expected for a 4 tooth blade. If you want smoother get the 10 tooth.
