Coen said:
Ha you are right. I apparently didn't use the CTL 22 with suction-attached dust collection adapter for years, if ever (it's "stuck" beneath the CS-50). The CTL 26 does power it's outlet when turned on in manual mode and keeps running regardless of what devices attached to it turn on or off.
So between CTL 22, CTL 26 and CTL Midi-I there are three different behaviors. The CTL-26 having the best, and Midi-I the worst.
Thanks both for confirming. Ref others, there is nothing preventing FT to make a different firmware for the CT 15/Mini/Midi series. It is just they are unlikely to do so unless customers do not complain loud-enough. Changing behavior mid-cycle is a no-no marketing wise.
IMO the current "big" series - CT26/36/48 - will achieve a bit of a legendary status once EOL. More so than the CT11/22/33/44 series even. .. Presuming FT gets rid of the manual dials on the "big" vacs at next refresh, still hoping they do not ..
OT:
Every time I think of which 2nd vac to get, after a couple "ideas" of a CT 15 here and CTL Mini there, I "settle" on a second piece from the CTL26/36/48 series .. then realise the budget is not there for that and so just give up. Been on that "cycle" at least 3 times by now.
The way this is going, inevitably I will grab a CTL 26 at one point to go along my CTM 36 .. aargh!
@OP: Happy sanding!
