- Jun 25, 2016
[size=18pt]Building on the earlier release of our DeWalt Trim Router Adapter Kit for the LR 32 System, we're excited to announce the Makita version, compatible with their popular XTR01Z and RT0701C model routers.
Festool’s LR 32 Hole Drilling System is one of the best ways to efficiently build cabinets using the standardized European frameless 32mm system, particularly when boring shelf pin holes in casework. Originally designed to utilize Festool OF 1400 or OF 1010 routers, this Adapter Kit makes it possible to use Festool’s LR 32 system with popular compact routers from Makita.
More than Just Boring Holes: Grooves, Dados & Rabbets, Too
Along with the adapter baseplate, this kit includes the TSO "Pivot Block." This block features an integrated magnet and attaches underneath the guide plate lever to keep the pin temporarily raised such that it will not engage the holes in the guide rail. This essentially transforms the LR 32 Guide Plate into a Guide Stop (minus the micro-adjust), allowing for continuous routing of grooves, dados and rabbets perfectly parallel to the guide rail.
Learn more about the LR 32 Guide Plate Adapter Kit for Makita Compact Routers.
What else is new at TSO?
JUST RELEASED! GRS-16 PE v2 Guide Rail Square for Festool, Milwaukee & Makita Track Saws
"Version 2" of our popular guide rail square now includes a fast attachment feature: simply insert the square at any point along the guide rail and clamp it in place—no need to slide it into the guide rail from one of the ends or remove hose deflectors, clamps, or other accessories occupying the guide rail T-slot.
JUST RELEASED! GRS-16 PE D Guide Rail Square for DeWalt Track Saws
The proven design of the GRS-16 guide rail square has now been adapted to fit the DeWalt track saw system! Like the original GRS-16 and GRS-16 PE squares, the GRS-16 PE D makes it lightning fast to achieve dead square cuts with your DeWalt plunge saw.
MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares for Festool, Milwaukee, Makita & Triton Track Saws
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
Padded Storage Bags for Precision Tools
Whether in the shop or on the job site, a little insurance for your fine tools is always a good move. Check out our new padded storage bags for guide rails up to 55" in length, parallel guides, and precision triangles.
