Finishing butcher block counter top.
Hello,
I'm working on finish a butcher block countertop for the pantry.
I was suggested to use the Osmo PolyX oil 3054.
I can't find them anywhere
Any other good alternative?
I like the Boos Mystery Oil that comes with John Boos countertops. It has to be refreshed a couple of times a year, but application is a snap.
Great. Thank you all.
I ended up picking up Osmo 3043 from Woodcraft.
Going to give it a try.
I read recently that cutting on countertops is a bad idea (from a sanitary point of view).  Separate cutting boards are preferred.
I put butcher block in my kitchen on all the counters except the sink counter which I have not yet replaced.
I created separate cutting boards from the scrap.
I applied four coats of oil based poly (gloss).  I did not put it to use for the first 7 days and for three more weeks I used coasters and silicone mats to protect the finish.  Regardless of what anyone says, the oil based finishes, especially if you are applying 3 or more coats, continue to cure for many months after application.
It is 8 or 9 years now.  No maintenance at all except to wipe down with a damp towel.  Still looks great with only tiny scratches in a few places.  I might just scuff it up one day and apply another coat.
I don't baby the surface.  My major investment in the finish is waiting for a month to put it to full service.  I was careful for a few months after that.
A week old poly in that thickness will pass my thumbnail test (scraping as hard as I can with my thumbnail) but will not ace the edge-of-a-copper-penny test.  The edge of the penny will not break through the finish, but will make indents.  A year later it will fully ace the test regardless of how hard I press and scrape.
I am happy with the oil based poly and the fact that it requires no maintenance.  (Minwax Oil based poly--nothing too exotic.)
A few years ago I fabricated a walnut countertop and from the leftover scrap, I made a cutting board that would fit in the Kohler sink. I finished both walnut pieces with Boos Mystery Oil and Boos Board Cream. It has the NSF certification. I've been very happy with the results.
[attachimg=2]
[attachimg=3]
I would use the Boos material for a cutting board.  But I would not use my countertop as a cutting board.
Boos is a highly respected manufacturer of butcher block and they certainly know their business.  Rajun has to decide if he wants to use the countertop as a cutting board or just a horizontal surface.
In any case you should not use the counter top to cut raw meat or fish, or only use it to cut meat or fish.  Don't mix usages.
https://foodsafety.wisc.edu/assets/... Butcher Blocks and Wooden Cutting Boards.pdf
