First MFT/3 only project - mail/paper sorter
ear3
A colleague of mine was complaining about the disorganization of her office, with papers scattered all over the place, so I offered to build her a mail/paper shelf unit.  My true aim, though, was to do a project exclusively on the MFT/3 which I just picked up the other week, and I thought this was a pretty simple and straightforward project with which to break it in.
I used 3/4 oak veneer ply with hardwood caps, and then 1/4 oak veneer ply for the shelves, which are removable to create a taller shelf if needed.  Since it will only be papers, there was no need to make the shelves thicker.  Everything was put together using dominoes, and then a guide-rail mounted OF1400 did the dados for the 1/4 shelves.  Never had to touch the table saw once, though I did do the initial rip of the plywood and oak caps on top of a couple of saw horses with the 3000mm rail, as the MFT would have been too small.
I was also excited because this is the first piece of furniture I've done since I got the ROTEX 150, so I wanted to see how sleek I could get the wood.  I went up to 800 with the Granat, and then finished off with the Platin 2000.  I'm not sure if the Platin did anything for me, as it was already pretty shiny with the 800.  I did, however, notice some inconsistency in the finish along the edges after doing a second application of Danish Oil.  It might have been due to the fact that i had to jump from 320 to 800 grit (I didn't have anything in between), so next time I might try to use 500 as a stepping stone.  I managed to fix it with the green Vlies, though this reduced some of the luster I was shooting for.  I'm going to see if a finish pass of white Vlies and then a buff with a felt pad might add more sheen next time (neither of which I had at hand).  I'm pretty inexperienced when it comes to sanding in the higher grit ranges, having been content in the past to stop at 220, except if I was working on the lathe.
All in all a pretty simple project, but one that really got me to appreciate all the things I can do with the MFT/3.  And I appreciate all the responses I got to the various questions I asked about issues with the project.
That looks really nice. Your mitres look GREAT!
Looks really well produced!
Clean lines and in proportions
Do the long shelfs not bow? Look like they need a face frame?
Adrian
Adrian
If I were going to redo it I might have integrated some support along the front.  But ultimately the shelves aren't going to support anything heavy, just pieces of paper and mail, or maybe the occasional electronic device, like a web cam, so I'm not too concerned about bowing.  And I wanted to keep the option of removing them in case the person wants to use the bottom shelf for books or something.  Thanks for the suggestion though.
Adrian
If you DO find the shelves sagging and begging for support, you could install bevelled support 'runners' under the shelf set in a few inches from the front edge. The supports would be essentially invisible since they are on the bottom side of the shelf, and would keep your front edge appearance at a slim 1/4" while still providing the extra support.
And the sports can be added to the existing shelves as long as you can match the finish.
