- Oct 16, 2015
I have seen them done wrong, where the side with the force against them is on the pins, rather than the tails, but these are angled the wrong direction. There is no trapping of the piece.
Now, to be fair, these are "fake" and only for decoration, but it is bothersome to my head. I could deal with the rather excessive angle, if it faced the right way.
I have questioned it multiple times, hoping it was just drawn by someone who doesn't understand how they work, to no avail. Finally, the project manager showed me a pic of an existing unit, at another location. Apparently, that's the way it's supposed to be?
Ultimately, this will be done with Walnut and Ash veneers, this was just me testing the fit and process.
The size and spacing are correct, it's just that this was done with laminate scrap, rather than wasting veneer.
Shaper Origin made cutting the template easy. The ability to off-set your cuts is very helpful, when making a template for use with a bushing. This made it possible to do the cutting with a tiny 2mm bit. The template serves double duty for cutting the negative space that way, then turned around for use with Origin, cutting the positive side.
It could be done in an analog way, and years ago I would have had to do that, but this sure saves a bunch of time. It also falls into that perfect niche, outside the range of a gantry-style CNC machine.
I should have blown the dust off, the joints are much better than they look in that pic [embarassed]
