After procrastinating for a while I finally pulled the trigger on. Df500 for an upcoming home library project.
some questions if anyone can help:
1) for 18mm plywood butt joints eg carcass assembly, are you using 30mm dominos with 15+15mm depths (i.e. leaving just 3mm left in the vertical sheet panel) or something different?
2) glue... Are you just glueing the length where the two pieces of wood meet or glueing in the dominos themselves?
3) for multiple shelf alignment, was thinking to make the left hand vertical dominos to be tight and right hand to be wider but for those that make bookcases etc, what did you find worked best?
4) further to the bookcase example, are you just using dominos for alignment eg 2 on each end and then supplementing with screws, purely relying on glue or adding more than 2 dominos to each shelf end? (Will be 350mm deep shelves, max span 700mm)
Thanks in advance
Thanks in advance
