Hello
I am working on my first project using a Domino XL to make a large, heavy table top and base. I used a story pole for aligning the mortises and stupidly forgot to account for the added thickness of the story pole in my first mortise. The hole is a little closer to the surface of the table than I'd like and I'm wondering a out the best way to fill it. I could glue a domino in the hole and cut it off. Alternatively I could fill it with epoxy.
Any suggestions would be appreciated.
Also what's is the recommended spacing on larger pieces? I'm using 7'x 6" x2" white oak pieces edge glued. I placed two Dominos at each end 3" apart and then one every 1 2" ( 12mm x 140mm) I think this is sufficient but could add more if necessary.
Thanks Paul
Thanks Paul
