Flatten a slab with OF1400
Hi all,
I'm looking to flatten a 10 foot slab 40 inches wide and 2.5 inches thick.  I only have an OF1400 and am wondering if its underpowered for a 1 inch Freud straight bit?
Anyone out here have words of wisdom?
Thanks,
Oscar
Cool. that's a thread that I started.  [big grin]
[member=30787]juststartingout[/member] the router should work ok. Just remember it's not a 5 HP spindle in a CNC, so don't try to hog off 3/4 of an inch in a single pass.
That's a good size slab. I have noticed lately that many of the folks that specialize in selling slabs have started offering flattening services as well. So you might want to inquire.
Ron
If it were me, Id use a RO150 with a blue pad (hard pad) start with a very course grit and work through the grits or a 850 planer.
Even better find a shop with a wide belt sander and see if they will run it through it a few times for you. Youmight have to kick him a few bucks but it will be worth it
As mentioned before 1" or 1.5" bit is fine for a 1400 Watt router. I prefer dish carving bit to straight one for flattening. It has rounded corners and makes transitions between passes less visible.
And for few more bucks they'll make you the entire table...  [poke]
and for a few more bucks he buy one prefinished  [doh]
I'd use a cheaper fixed base router personally.    Ebay special.
I know doing it yourself sounds exciting but you might do as some other have suggested and call around to see about wide belt service.
I use the Festool sled (MFS-FS) and routing template (MFS 700) combined with my OF1400 for this. Search for Festool 495648 Routing Slide. Up to now it has done a good job for me. Maybe it will meet your needs as well?
Router sled is about the only thing that works to take cup And twist out of a large piece. Much nicer to work on a 200lb or greater piece without having to constantly move it.
I use 8020 extrusions...
View attachment 1  I have 96" 1530s that I use but I could get up to 20'ers if I was to buy from a distributor rather than the 8020 Ebay store.
I also have 1545s although shorter versions.  These could be used for longer stiffer versions for the side quides.
I’ve used a 3/4” or 1” diameter bowl bit in a 1010 for flattening Brazilian cherry. It worked fine and reduced the “stepping” transitions in the flatenning process. Less work for the sander.  [big grin]
I use an Amana Tool 45453 carbide-tipped straight plunge bit in either the OF 2200 or the OF 1400.  Another good option is the Whiteside #6220 Spoilboard Cutter.  No bowls to sand out either way, [member=44099]Cheese[/member].
