Flip stops for KA-UG extensions
broseiden
Are the flip stops available for purchase independently of the extensions? I tried searching in EKAT, but maybe I'm not using it properly.
Thanks! - MIKE
SMJoinery said:
I'm fairly sure part number is 488560.
That's for the older discontinued extension set. AFAIK, the "Stop Flag" on the KA-UG arms is not available as a single part number.
Not sold as one part but only the replacement parts according the EKAT.
From #497207 or 497221 you need parts: 2, 5, 9, 10, 11, 12, 13 and 15.
As Tom said you can use either flag stop. When I flip the stops down I leave it up off the surface. Nothing will screw up a setting faster than sawdust between the work piece and the stop. Take a look at the farthest stop in the picture, you will see the long arm is towards the UG support surface.
Thanks everyone -- ended up buying a total of 5 to use between my MFT and Kapex :)
Plus the included ones, that is :D
