Flush cutting with TS55? How close to wall?
eightball
Okay, I'm stuck away from my TS55 (otherwise I'd measure it myself) - so thanks in advance for the help.
If you're flush cutting to a wall what's the closest cut you can do?  Said differently what's the dimension from the wall to the outside (farside from wall) of the kerf?
I seem to remember 12mm but I can't find it anywhere googling or searching here.
If anyone knows it off hand it'd help me get a jump on some planning over the holidays.
Best,
Anthony
That's for the TS55 REQ though right?  The TS55 has a lumpier housing if I remember right.  I'm also at the office away from my Festools. [sad]
My TS 55 REQ does to 12mm off the wall, as skirting boards are usually 15-19mm the cut is covered by the skirting.
