Mario Turcot
- Nov 26, 2017
I used a few different flush trim bits so far. All on a single bottom bearing. My experience with flush trim bits (cheap ones) is that often the bearing will not hold long or will mar the bottom part. What is your preferred flush trim bit and single/double bearing?
I received this news letter..
Flush Trim
.. from Infinity Cutting Tools and found the bits interesting. This is the first time I see a bit with that kind of pattern. Your thought?
Crazy thought: Since I don't have a router table yet, do you think I could use the Nova voyager drill press to flush trim boards?
Flush Trim
