Found a used Ts55 and mini extractor for sale. Good deal or no?
lseap107
Hello, I found a used Festool Ts 55 saw with 55" guide and a mini extractor for sale.  He is asking $675 for both items.  Not sure of the age but he stated they are in very goo condition with average use on them.  They look pretty good in the photo but I was wondering if this would be a good price or not?  Any thoughts?
Thank you,
John
Looks like current price is $919. If they are not beat up and aren't going to cost you a fortune to ship seems like an awesome deal to me. Festool tends to hold its resale value well. I'd say go for it if it's what you want need.  [unsure]
welcome to the fog. sounds good. if you can go and see them and see if they sound and work properly
If you can't determine their age before you buy, assume that they're out of warranty.  But the warranty transfers, so you might want to check the serial numbers with Festool to see when they were originally purchased.  To those who know, is that something you can do?
i presume it can be done. if you asked for the seriel no it should show up any iregularities adn show you if the seller is legit
Thanks for the replies.  I really wasn't looking for it but stumbled across it.  I think it would be a helpful addition when cutting plywood.
[welcome] to The FOG!
There is not much which can go wrong with a Festool CT. It either works or it does not work.
The same is not so true of a TS55. Have you recently looked up the price of a replacement blade? What if the Plug-It cord is in bad shape? Suppose that TS55 was dropped? The all-important toe-in setting could be slightly off or worse, toed-out. Such condition turns a fine saw into one producing horrible results. If you have not been taught how to check and adjust the toe-in setting on Festool TS saws, do you have inexpensive access to someone who is experienced making those adjustments?
You mentioned that a 1400mm (55") guide rail is included in this deal. Will it need a replacement splinter guard? Is the guide rail bent? That can and does happen even with new TS saws and guide rails purchased from dealers needing to ship to you by common carrier. My own preferred local Festool dealer receives pallet-loads of product several times a month. Festool carefully packs the guide rails such that the rest of the material on a pallet protects them, but good luck shipping a 55" rail in its factory carton by UPS or Fed-Ex.
Carrol is right on about what could be wrong.  My advice is to try the tools out if that is possible because there is a good chance that they will be fine.  First thing to check out is the manufacture date printed on the label, month and year (11/12 being November 2012).  If they are newer ask a bout purchase date and warranty.  As of a year and half ago most tools started coming in the T-Loc Systainer and that adds some value over the older classic Systainer.
Try the a test cut or two id possible.  The saw has a soft start and it has a bit of different sound than you may be used to with other tools.  The sound is sort of a groan almost like the bearings are going.  Don't worry that's normal.  If everything is good you should have a very good cut in plywood, no burning or saw marks.  As for the vac, it has a small diameter hose to attach to the tools so it dosen't pick up dust like your shop vac might with the larger diameter hose.  You should get a good dust collection with your cut but expect a bit of dust to escape especially at the end of the cut.
Here's the sound of the TS55.
Thanks for the good advice.  The sale of the saw and extractor is a local sale so I will be able to try it out in person.  It looks like one of the newer style sustainers in the photo.
A local deal avoiding shipping and allowing personal trial of the tool is always best.
I would not only bring along some of my own plywood, I would also bring a trusted level or straightedge to double check the guide rail.
